Cisco E EA Router Setup with Bluesound
Follow
 BLS TB13-402
Introduction
This technical bulletin describes specific settings for the Cisco/Linksys E and EA Series routers that are needed for Bluesound products to communicate. It does not document the steps required to setup a network.
Scenario
The Bluesound products use the mDNS/Bonjour protocol for node discovery. This is a multicast protocol, but it cannot traverse network subnets. It is possible that the router may block the multicast traffic, or it may not have the most up to date mDNS/Bonjour support. These problems affect both iOS and Android.
The problem occurs when some or all Bluesound nodes cannot be seen in the Right Side Navigation Drawer of the BluOS app. It may be possible to ping or open a web browser on the Bluesound node, but the BluOS app will not find the node. If you do an iNet scan on the Bluesound node, the node will appear but no Bonjour Services will be available on that node.
This problem is intermittent. Sometimes disabling and re-enabling the Wi-Fi network on the device will solve the problem. Often, rebooting the router will fix the problem temporarily.
Configuration
Access the router through a web browser. The default username and password are both admin. Go to the Security -> Firewall page and enable Filter Multicast. Reboot the router when done.
Notes
Please download the latest version of your router firmware from Cisco's Support Site. Early production E/EA hardware including the Cisco E4200 have had upgrades added to their firmware that will improve the routers ability to perform with mDNS/Bonjour protocols. The latest firmware currently for the E4200 is v1.0.05 (Hardware Version 1) dated 09- 27-2012.
