How do I eject my CD from the Vault?
Follow
BLS-KB13-Y14
As a CD ripper, the Bluesound VAULT should eject the disk automatically after the Rip/Encode process is finished.
There are two ways to have a Bluesound VAULT to eject your disk before the Rip/Encode process is complete.
Software Eject:
With your Bluesound VAULT selected in your BluOS App, select Settings, Music Library, Ripping. There you will be provided with the option to Eject CD.
Hardware Eject:
Bluesound automatically ejects disks when set into Upgrade mode. To place the Vault in Upgrade mode:
  • Disconnect the Bluesound VAULT power cord from the wall.
  • Wait 5 seconds and reconnect the power cord.
  • As soon as the Bluesound VAULT's LED turns red, press the Play/Pause button for 5 seconds after the LED has turned green and release.
  • The CD should Eject momentarily.
  • Follow the on screen prompts in the BluOS App to run an upgrade and return the Bluesound VAULT to service - if no upgrade is required, no harm will come to the player by running the upgrade.
