How do I know which connection Bluesound is using if configured to both Ethernet and Wireless?
Follow
BLS-KB14-404
Scenario
A Bluesound player, connected by wireless is re-booted with Ethernet connection inserted into the LAN port.
Explanation
To check if you are connected to either Ethernet or Wi-Fi, select HelpDiagnostics in the Navigation Drawer of the App.
If the Diagnositcs for the Player you have chosen displays a color coded signal strength indicator and a dBm reading, it is connected via wireless. If these do not show up, this Player is connected via Ethernet.
By default, if a network cable is attached to a Bluesound Player, it will always attempt the wired connection first.
