Introducing BluOS 1.12.0 for Bluesound Players
Follow
In the latest software, BluOS version 1.12.0, Murfie and HDTracks are now supported, giving you the freedom to stream massive collections of lossless music and access high-res downloads directly from Bluesound wireless high-res music systems. Also includes support for local library playlists, folder browsing and other new music management enhancements.
ENHANCEMENTS
Experience vinyl music like never before.
Browse Murfie’s vinyl and CD inventory of 500,000 new & used albums and stream lossless music directly to any Bluesound Player in your home. Even access stored vinyl and CD rips from your online Murfie collection on the fly with the BluOS Controller App and listen to them house-wide on multiple Bluesound Players simultaneously.
Learn how to set up Murfie here
Download the best music collections on earth.
Explore HDTracks and its premiere online music store to discover the best sounding music on earth. Get on-demand access to the online music store and download high-quality recordings directly to the Bluesound VAULT. Stream all HDTracks downloads to your full HiFi system with the NODE or with any Bluesound Player.
Learn how to set up HDTracks here
Browse more of your library faster and easier.
Search your local library folder and playlists, or cross browse between music stored on your network and your favorite music service, directly from the BluOS Controller App to make music browsing and listening easier than ever.
*Includes Polish language support and other minor software enhancements.
HOW TO UPGRADE
Before upgrading, please make sure the BluOS Controller App* and Desktop Controller* have been upgraded to the latest firmware:
*BluOS Controller App for iOS, Android and Kindle Fire, version 1.12.0 or higher.
*BluOS Desktop Controller for Mac and PC, version 1.0 or higher.
Bluesound Players will send a notification for upgrade within 24 hours to the BluOS Controller App and Desktop Controller on iOS, Android and Kindle Fire devices. If no notification is received, please visit www.bluesound.com/downloads for the latest BluOS Controller Apps and BluOS firmware updates.
WITH BLUESOUND CONTROLLER APP
In order to force an upgrade to begin, the option "Check for Upgrade" is available past the "Configure Player" option. This will force the upgrade prompt to occur.
Open the left-hand Navigation Drawer of the BluOS Controller App. Scroll to the bottom and tap Configure Player Check for Upgrade
WITH USB STORAGE DEVICE
If the Bluesound Player is unable to connect to the internet (wired or wireless) due to poor connectivity or router settings, BluOS 1.12.0 can be downloaded onto a USB storage device and inserted into Bluesound Players to perform an upgrade.
Visit www.bluesound.com/downlaods to download the latest firmware for manual Player upgrades.
Disconnect the power cord from your Bluesound Player and insert the USB device into the input on the back of the Player.
While pressing and holding the Play/Pause Button on the Bluesound Player (see further for the PULSE Player), reconnect the power cord and continue to hold the Play/Pause Button for 5 seconds then release. The PULSE requires power before the Play/Pause Button can be pressed to start the upgrade. Reconnect power to the PULSE before pressing and holding the Play/Pause Button as instructed.
The Bluesound Player will now start to copy the file from the USB device and enter Upgrade Mode. The Play/Pause Button will begin blinking an alternating pattern of green and red to indicate this.
Once completed, the Bluesound Player should reboot on its own and return to normal functionality. You can now remove the USB device from the back of the Player.
