Introducing BluOS 1.12.3 for Bluesound Players
Follow
BLS-KB14-Y04
The latest software, BluOS version 1.12.3, is a maintenance release that fixes a recently identified issue in which a Bluesound Player may not find local library content.
HOW TO UPGRADE
Before upgrading, please make sure the BluOS Controller App* and Desktop Controller* have been upgraded to the latest firmware:
BluOS Controller App for iOS, version 1.12.0 or higher.
BluOS Controller App for Android and Kindle Fire, version 1.12.3 or higher.
BluOS Desktop Controller for Mac and PC, version 1.2.0 or higher.
BluOS Players will send a notification for upgrade within 24 hours to the BluOS Controller App on iOS, Android and Kindle Fire devices. If no notification is received, please visit www.bluesound.com/downloads for the latest BluOS Controller Apps and BluOS firmware updates.
WITH BLUESOUND CONTROLLER APP
In order to force an upgrade to begin, the option "Check for Upgrade" is available past the "Configure Player" option. This will force the upgrade prompt to occur.
Open the left-hand Navigation Drawer of the BluOS Controller App. Scroll to the bottom and tap Configure Player Check for Upgrade
WITH USB STORAGE DEVICE
If the Bluesound Player is unable to connect to the internet (wired or wireless) due to poor connectivity or router settings, BluOS 1.12.3 can be downloaded onto a USB storage device and inserted into Bluesound Players to perform an upgrade.
Visit www.bluesound.com/downlaods to download the latest firmware for manual Player upgrades.
Disconnect the power cord from your Bluesound Player and insert the USB device into the input on the back of the Player.
While pressing and holding the Play/Pause Button on the Bluesound Player (see further for the PULSE Player), reconnect the power cord and continue to hold the Play/Pause Button for 5 seconds then release. The PULSE requires power before the Play/Pause Button can be pressed to start the upgrade. Reconnect power to the PULSE before pressing and holding the Play/Pause Button as instructed.
The Bluesound Player will now start to copy the file from the USB device and enter Upgrade Mode.The Play/Pause Button will begin blinking an alternating pattern of green and red to indicate this.
Once completed, the Bluesound Player should reboot on its own and return to normal functionality. You can now remove the USB device from the back of the Player.
