How do I browse my Local Library by folders or directories?
Follow
BLS-KB15-102
From the Library  in your BluOS Controller App, you can select Folders as an option; this will show you the directories for any Shared Folders that you have configured with your Bluesound Players. Bluesound Vaults will also appear in this listing.
Notes
  • The directories noted via Folder Browse are created by indexing your folders. New files in your folders will not appear until you perform a Rebuild Index or Reindex Music Collection command.
  • Files removed from your folders will disappear from Folder Browse.
  • If you are noticing issues with displaying the results of Folder Browse, make sure your Bluesound Player, as well as your Device with our Bluesound App, are on stable network connections.
