Can I Dim the LED on my Bluesound Player?
Follow
BLS-KB15-705
With the release of BluOS 1.18.x you can now disable the LED on your Bluesound Gen 2 Players as well as on the original Bluesound Node, Powernode and Vault. In the Configure Player Menu, select Indicator Brightness and set the option to Off. On Bluesound Gen 2 Players, you can also Dim the LED. To re-enable, set the Brightness to Normal.
Notes
  • Dim is not available on the Original Bluesound Classic Players
