Can I use my TV remote to Control Bluesound?
Follow
BLS-KB15-805
IR Support is available on most Bluesound Gen 2 Players and the PULSE SOUNDBAR. IR support is not possible on Bluesound Classic Players nor the Bluesound PULSE FLEX. To program IR Remote commands into a Bluesound Player with IR, in the Settings Menu, select Player, IR remote. Simply select the function desired from the IR Remote Menu, point an IR remote at the Bluesound Player and press the button to perform that function. Once programmed, a check-mark will appear in the Configure IR Trigger function list.
Available programmable options are;
 Optical (TV Mode)
 Play
 Pause
 Play/Pause Toggle
 Mute
 Next
 Previous
 Volume Up
 Volume Down
 Preset (1-5)
When using a remote to control volume on a PULSE SOUNDBAR, check your television audio settings and disable the built in speakers of the television.
Notes:
  • Optical Input (TV Mode) will set the source of the Player to Optical Input and is ideal for programming with the Power button of your TV remote.
