Introducing BluOS 2.8.0
Follow
BLS-KB16-Y02
Have more control, in more rooms than ever before with Fixed Groups. Using the new re-designed Player Drawer and its enhanced grouping features you can now easily stereo pair two Players or combine multiple Bluesound Players into one easy-to-manage, pre-programmed group. You can even remove a Primary Player from a Group now, letting you build groups with freedom and without stopping or removing any music. Leaving a room and headed to the next one? With FollowMe you don’t have to worry. Simply tap the FollowMe icon beside a Player in the Player Drawer to seamlessly transfer the current play queue to any Room or Player you’d like.
Software Requirements
BluOS Controller for iOS, version 2.8.0 or higher
BluOS Controller for Android and Kindle Fire, version 2.8.0 or higher
BluOS Controller for Windows PC and Mac OS, version 2.6.0 or higher
What’s New
FollowMe to move the currently playing music from one Player to another
• Use Fixed Groups to create permanently grouped players that appear as a single Player in the App
• A new Stereo Pairing set up wizard
• Remove a Primary Player from a Group
• MQA badge appears on MQA content when browsing Local Library before playback
• Enhancements to Artwork display in the Local Library
